mamba 25 +4 cell lipo?
so can the mamba 25 run 4cell lipo?
im sure it would need a bec and hv cap i have a 3500kv hacker motor i want to run on 4 cell in my mini lst, if the mamba 25 can't do it whats the smallest esc that can? thanks |
yes it will, my tekin mini rage ran awsome on 4s. and all the mambas will handle it.
Yes it will, just like the MM handles 4S perfectly with a BEC installed. I believe the major difference between Sidewinder and its bigger brothers is the number of MOSFETs mounted, which affects current spec, not voltage.
stage 1 mods done and it went up in a ball of flame. |
5s worked on my mini rage when the pack was at nominal voltage.18.5. when i peaked the lipos 21v, it stuttered and the smoked. ran 73mph in 1.7 seconds using tekin mini rage with 8.0kv mini motor.
Do you know that's 148000rpm?
in drag racing it never reaches full rpm. over gearing actually makes it take of faster, so im guessing it only saw 50,000rpm
It will work on 4s with BEC and no cap installed, but we will not cover the ESC under warranty if something happens when running on 4s. Make sure your batteries are more than capable of the current draw. 20C rating and 1500mah+.
its out of warrenty any way:lol: is there a set of caps i should change it to? |
No need to change the caps...they'll handle 4s just fine as long as you use a capable battery pack. I've run 4s on a 6800...stupid fast...stock up on diff sets. LOL
| All times are GMT -4. The time now is 08:37 AM. |
