-   -   My setup! (https://www.rc-monster.com/forum/showthread.php?t=16982)
BL_maxx 12.01.2008 04:24 AM
My setup!
well i finally got my set up done only thing i will need is lipos later on down the road.
here is the setup on my truck
Emaxx 3905
MMM v2 with new firmware
C50 9xl clone motor from bidproduct
14 cell spc packs
21t pinion
stock 68 tooth spur(have 62 and 65t waiting in the wings)
and i just ordered my new charger i got
MRC Super brain 989
Astro blinky balancer
you guys think the charger and balancer i got will be good for 5s? i know that the charger can charge up to 8s but i wasnt sure if it will do it in a timely manner. i plan to stick with the zippy and true rc packs would the blinky work with those?
thanks again! and cant wait to get my stuff!! should be here soon and cant wait to ge some video up too.
suicideneil 12.01.2008 06:29 PM
The blinky should work fine with the zippy lipos, not sure what balance taps the truerc lipos use- a picture would be handy there. The specs dont list the power output of the charger in watts, just its amp and volt ratings, but Im gonna guess its got to be more than 50watts given its good for 10amps of charge current. In that case, it should do most lipos in one hour, which is a 1c charge rate at any given current/ mah capacity.
One more thing:-
http://i18.photobucket.com/albums/b1...ithoutpics.jpg
BrianG 12.01.2008 06:46 PM
The 989 has a power limit of 120w. You should be able to charge your 14 cells as high as around 5.5A without hitting that limit, depending on how high they peak out at (I'm assuming 1.4v/cell).
BL_RV0 12.01.2008 07:59 PM
Cool. Hope to see lipos in there soon (or the truck at all!)
BL_maxx 12.01.2008 08:26 PM
lol ill get pics of the truck once i get home from work.i dont have pictures on my work computer lol. hopefully the parts come in before i get to the desert that way i can take the maxx with me!
cool and i dont think i will have a problem. all the lipos i plan to get are around 5000 to 8000 mah and i dont mind waiting an hour or so.
BL_RV0 12.02.2008 12:15 AM
That's good. Just be ready for insane power when you get the lipos...
BL_maxx 12.02.2008 03:24 AM
here is the picture of when i got the truck
http://i97.photobucket.com/albums/l2...1/DSC02166.jpg
http://i97.photobucket.com/albums/l2...1/DSC02165.jpg
fixing the shaft i broke after two packs
http://i97.photobucket.com/albums/l2...1/DSC02171.jpg
i havnt taken any new ones. ill take some tomorrow because its too cold to go get my maxx from teh workshop right now! and im tired but as soon as i get up ill get them going i need to tidy the wiring up though it kinda looks busy in there lol.
BL_maxx 12.02.2008 01:59 PM
alright i just took these about 10 minutes ago. sorry about the quality the iphone camera kinda sucks. i cant find my good camera.
http://i97.photobucket.com/albums/l2...1/IMG_0199.jpg
http://i97.photobucket.com/albums/l2...1/IMG_0198.jpg
http://i97.photobucket.com/albums/l2...1/IMG_0197.jpg
BL_maxx 12.02.2008 02:55 PM
i just checked my package status from tower! and itr say its out for delivery!! even though it says that it is scheduled to deliver for the 3rd of december you think i will get it today? thats what i dont understand sometimes. well hopefuly i get the stuff before i go to work so i can mess with it lol.
suicideneil 12.02.2008 03:59 PM
Not bad- any specific reason you are using the lower motor mounting location rather than the central one? I doubt your stuff will turn up today though- it may have left towers warehouse, but your local postoffice may kidnap it at some point...
BL_maxx 12.02.2008 04:07 PM
to answer your question neil it rubs in the upper mounting hole. the motor is too fat but im going to mess with it a bit to see if i can get it to go in there.
hopefully it does though because i wouldnt expect that from UPS maybey from USPS. even if it arrives tomorrow it will give me a day to mess with the charger and settings on my MMM and get it right.
so is your motor stil alive?
suicideneil 12.02.2008 04:17 PM
Yep- not ran it for a little while due to the weather and short daylight hours; it gets dark at 4pm! Good motors though for the price, the fins do make a difference to shedding heat it seems, at the cost of a larger diameter as you found. Thats about my only gripe really- they even come with a flat spot on the shaft now which is a nice touch- I had to grind my own.
BL_maxx 12.02.2008 04:29 PM
thats good to hear neil. yeah i noticed that too. mine came with the flat spot ground on it. i cant wait to get this pupy going. im going to try 21/68 first and see how the temps are and hopeully i can use 21/65
has any one had any luck with these lipos?
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
and i think im going to get these ones for sure
suicideneil 12.02.2008 07:23 PM
I have the 5s 4000mah 20-30c lipos, I busted my tranny twice before I could run them down fully- mucho power there...
If you gear for no more than 40-45mph, then both lipos and motor will do excellently, but it depends alot on weight and gearing- your lighter truck has me at a disadvantage, so you should get better results and not need any cooling down breaks for the motor.
BL_maxx 12.02.2008 08:22 PM
YAHOOO!
my shipment came in! the charger is pretty small. cant wait to use my truck later tonight! and all i need is the lipos and im good to go. so hopefully i can run a least the set of packs though. probally get a video up later on this week or next week,
