Tamiya high lift radio
what kind of radio is required for use with the high lift tundra? i thougt it was a 4 channel buteverything i read says 2 channel. i dont see how thats possible because its a 3 speed tranny right?
You would lock it into a gear.(1st 2nd 3rd) and then only need steering and throttle/
and if you want to be able to shift then you need a 4 channel?
you would need 3
Throttle, steering, shifter |
so would a traxxas tq3 work?
| All times are GMT -4. The time now is 11:17 AM. |
