-   -   Chargers (https://www.rc-monster.com/forum/showthread.php?t=17136)
trev3813 12.08.2008 12:40 AM
Chargers
Im looking for a decent, all around charger, this one will do more than i'll ever need, because my E-Revo some day will be 6s, so its perfect. Is it a decent charger, and what power supply would i need to get?
http://www.amainhobbies.com/product_...ducts_id/22872
rchippie 12.08.2008 12:49 AM
That charger will work fine . But it will take a while to charge because of the low wattage . this charger will charge your lipo faster . It's what me & alot of of other members use .
http://www.rc-monster.com/proddetail...OS0610I&cat=19
trev3813 12.08.2008 12:50 AM
Thats a really nice charger, but i only have 150, maybe i'll save and get that one.
rchippie 12.08.2008 12:56 AM
I understand but it's only a few bucks more & you will never have to buy another charger . It will be able to charge your 6s lipo at a much higher amp rate than the other charger . Ask for other members opinion on which charger is better .
E-Revonut 12.08.2008 01:54 AM
I'm certain that you won't be happy with the 0606i, it's a good charger and all but not for a dual battery setup such as the e-revo. You said that someday you'll run 6s so I'm going to assume for now your running 4s. The 0606i will charge a 2s pack at up to 6amps so 2 hours to charge 2 seperate 2s 6000mah packs. If you where to go to 6s (2x3s) 5000mah is the biggest pack that will fit. That same charger will only charge a 3s pack at about 3amps so it would take about an hour and 40 minutes per pack! I know this because I started with the eos 0606i ac/dc charger. I now run a eos 0610i duo with an 18 amp Ofna power supply. It will charge 2 3s packs at 1C without a problem! The charger is costly but it should meet your charging needs forever!
trev3813 12.08.2008 10:13 PM
Converted nitro Revo
E-Revonut 12.08.2008 11:43 PM
Single 4s pack then I'm guessing. Means the most the charger will charge at is 3 Amps so if you have a 5000mah pack your looking at about 1:45 to charge the pack, 6000mah will likely take about 2:10
e-rev project 12.09.2008 01:08 AM
i'm really happy with my EOS0610I . I'm glad i spent the extra cash and went with quality and power. it's powered by a 25amp radio sack power supply
Arct1k 12.09.2008 07:13 AM
The 606 is limited to 50W which is why it is slow - It is still a very nice charger - Just a bit slow on bigger packs...
pedeboi364 12.09.2008 07:33 AM
Go to hobbyking.com (hobbycity.com) and pick up a Turnigy Accucel-6 and IMax 16A 14V power supply, all for under $80.
Duster_360 12.09.2008 07:54 AM
The Accucell-6 is a nifty little charger - I've been using one for about a month and it is a very featured charger, will pretty much do everything. Its limitation is that it's only a 50watt charger. Within that limit though, its hard to beat, especially given the price.
asheck 12.09.2008 09:16 AM
http://www.hobbycity.com/hobbycity/s...r_&_discharger My buddy just got 1 of these.It seems to work good.With http://www.hobbycity.com/hobbycity/s...y_for_Chargers it's around 120 shipped,and will give you a 200 watt combo.
trev3813 12.09.2008 03:23 PM
I found a Hyperion EOS0610I 250W 6S 10A for $150
e-rev project 12.09.2008 03:38 PM
apparently the EOS0610I is out of production already, its being replaced by the EOS0720i http://media.hyperion.hk/dn/eos/
pedeboi364 12.09.2008 03:55 PM
no means to thread jack here so will someone pm the answer to me?? ok, so my Q is will this 50w charger can supply the power to charge 2x 3s1p (6s) 5000mah at 5amps?? how many amps should i look to get?? thanks all!!!
