-   -   A couple of questions (https://www.rc-monster.com/forum/showthread.php?t=17199)
Marvin 12.10.2008 12:46 PM
Hi all
Set up:
Batteries : 2 4900mAh Trakpower in series (so 4s)
ESC: MMM
Motor: 2650kV CC Neu
My 1st question is:
Would 4mm Gold Tubes (Corally connectors) be good enough to run on a brushless conv in a truggy? Would they handle the current?
My 2nd question is:
Does the MMM have a switch, or is it just plug in the batteries and it comes on? It would be good if it did have a switch as I'm not running the BEC.
My 3rd question is:
What voltage do cooling fans generally run on (e.g. the MMM's cooling fan) as I'm planning on having a few of these...
Thanks guys, I'm sure your advice will be ace as normal...
Simon
_paralyzed_ 12.10.2008 12:59 PM
1. they should handle the current
2. it has a switch
3. 6v
4. fans shouldn't be neccasary with sensible gearing
BL_RV0 12.10.2008 08:15 PM
Do you have a picture or link to these connectors? It would be easier to tell that way if they will handle the current or not.
dirt101 12.10.2008 08:18 PM
4mm connectors will handle the juice fine but if i remember correctly they will not fit over the 10g wires on the MMM.
BL_RV0 12.10.2008 08:21 PM
They do if you strip the connectors down to 12ga size.
