-   -   Scorpion esc or MMM esc??? (https://www.rc-monster.com/forum/showthread.php?t=17267)
jalodo56 12.13.2008 07:50 AM
Hello I have a e-maxx with medusa 60mm 1600kv on 6s, but I don`t know what esc mount, the mmm or scorpion 6s 120A???
Regards
sikeston34m 12.13.2008 08:52 AM
Regards
I am running the Medusa 60mm 1500kv motor with 18/40 gearing in an E Revo. Powering this in my setup is the MMM. Very Fast and smooth setup. I couldn't be happier with this ESC.
The Scorpion has the power handling ability, but it doesn't have car mode in the software. You won't have reverse. I've also heard reports that most airplane ESC's lack alot in the braking department.
Alot of setups use mechanical brakes along with a HV Airplane ESC, which appears to make a pretty good setup. But again, No Reverse.
+1 Vote for the MMM. I hope this helps. :yes:
jalodo56 12.13.2008 11:03 AM
ok, but in the spec of the programming of the scorpion puts CAR/B= 1. WITH OUT REVERCE 2. WITH REVERSE, (BRAKE ON PRESET LEVEL ), then the esc is available for car no?
Regards
BL_RV0 12.13.2008 12:00 PM
The car scorpion esc is still in development. I'd just go with the MMM. I have one and couldn't be happier. Only the smallest bit of cogging with my 6 pole motor.
TexasSP 12.13.2008 12:01 PM
Having car settings and car software is two different animals. The settings are simple enough to program however actually having the software designed for car/truck use is another thing entirely. Things like braking, throttle, etc are much more complicated/different in a car/truck versus a plane.
BL_RV0 12.13.2008 12:02 PM
Yeah, even when the scorpion esc is developed I doubt that the braking will be proportional.
jalodo56 12.13.2008 01:00 PM
Thanks, then, I am going to buy a mmm or BK 9918 or BK 9920 or BK 12020?, Which is the best??
regards
BL_RV0 12.13.2008 01:21 PM
MMM by far.
TexasSP 12.13.2008 01:24 PM
BK are yesterdays news and no better than an old newspaper. The MMM is superior on every level, and the CS at Castle is world class.
jalodo56 12.13.2008 01:38 PM
ok, whit the mmm on 6s, need I external bec?.
regards
BL_RV0 12.13.2008 01:42 PM
No, internal bec works with 6s.
jalodo56 12.13.2008 01:47 PM
ok, The mmm v3 + medusa 60mm 1600kv on 6s with zippi 5000mha is good option for e-maxx?? How much autonomy will I get?
Regards
BL_RV0 12.13.2008 01:49 PM
I'd go with a 70mm medusa.
jalodo56 12.13.2008 01:56 PM
ok, but I have a medusa 1600kv 60mm, I just lack the esc.
regards
BL_RV0 12.13.2008 02:05 PM
Oh ok, I thought you didn't have the motor yet.
