-   -   Will the hotbodies hardened diff internam gears fit the CRT DiFF (https://www.rc-monster.com/forum/showthread.php?t=17280)
riverat1540 12.13.2008 07:53 PM
i have a crt and was wondering if there are there any hardened internal diff gear sets that will fit in the crt diff case as i stripped an aluminum gear inside already
cheesecake 12.13.2008 09:49 PM
you will be fine with the standard crt diff gears i reccomend replacing the diff cup also when you replace the gears incase the case has gotten warped from use
Semi Pro 12.13.2008 10:06 PM
yes they do fit
joeling 12.31.2008 03:39 AM
Yes they fit. My LHS owner also says the savage diffs fit also but I have not tried yet
Regards,
Joe Ling
Semi Pro 12.31.2008 09:03 PM
savage diffs are the same as hotbodies and ofna
lincpimp 12.31.2008 09:25 PM
I will say that the HB hardened internals will NOT fit a losi lst diff. They should fit any kyosh, ofna HB (of course) diff out there, including the crt diffs.
Savage diffs are slightly different in length, so you may need to shim other mfg internals to fit...
riverat1540 01.01.2009 02:40 AM
right on good to know found a hardened lsp center diff for cheap so just swapped it out and i blew the front so will also be changing that out as well
Semi Pro 01.01.2009 12:33 PM
this might be off topic but any diiff you can run hotbodies hardend gears in you can also run ofna aluminum cross pins in too
