-   -   velcro on MMM (https://www.rc-monster.com/forum/showthread.php?t=17337)
ReV:-O 12.17.2008 06:13 AM
velcro on MMM
Hi,
im thinking about gluing one side of velcro on my MMM and the other side on my e-revo to hold it on. will i void any kind of warranty on the MMM by doing this?
does anyone know what velcro i should buy? i went on the velcro website and there are so many different types!
thanks
ReV:-O 12.17.2008 06:25 AM
these two look quite good:
http://www.choiceful.com/choiceful-i...m-x-100mm.html
http://www.halfords.com/webapp/wcs/s...UEkVjO0bo#dtab
i think they are the same. will they do the job ok?
cheers
_paralyzed_ 12.17.2008 07:26 AM
always back up your velcro or 2 sided tape with a zip tie. The forces created will rip the mmm right off most velcro and tape. it won't void the warranty
brushlessboy16 12.17.2008 07:49 AM
I tried everything to get my MMM to stay down. eventually cut out a square of the bottom sticker and Ca'ed the velcro to it. no problems yet :)
ReV:-O 12.17.2008 07:51 AM
Oh right. how would i zip tie it?
the velcro stuff seems pretty strong, says it can hold up to 15kg!
azjc 12.17.2008 10:59 AM
you can get velcro @ Home depot....it will get the job done
Arct1k 12.17.2008 11:06 AM
That would be B & Q for someone in the uk....
E-fanatic 12.21.2008 09:59 AM
I tried the velcro but in a hard hit it would come loose , so I hot glued mine down. So far so good! The good thing about the hot glue is that when I need to take it off it will peel off or hit it with a hair dryer and it will melt off! My only issue now is that the case pops open some times after a big jump
brushlessboy16 12.21.2008 11:07 AM
I used some industrial plastic velcro that i got from a freind, 20lbs/in the adhesive that came with it sticks well to aluminum but not so great to plastic-I ended up Ca'ing the velcro to the mmm case(cut a square out of the sticker)
