Rc Monster 2 speed 2nd. gear
Has anyone used the RC Monster 2 speed 2nd. gear, http://www.rc-monster.com/proddetail...peed2nd&cat=40, with TiNi spurs from the LST2?
Yep, they fit fine. I will be using that adapter with the tin coated gears on my 2 speed 7th scale on road car speed project. I had planned to use it on my lst, but decided to use the tdr single speed hub and a regular pinion.
I wasn't worried about the fit. I had head that non-TiNi pinions wear out quickly when used with the TiNi spurs.
So are Mike's steel or aluminum?
| All times are GMT -4. The time now is 01:37 AM. |
