-   -   Which buggy gears? (https://www.rc-monster.com/forum/showthread.php?t=17416)
brushlessboy16 12.20.2008 12:58 PM
Which buggy gears?
Im planning on Doing a Small gear conversion and buggy diff conversion on my Cen Matrix Tr. Uses standard sized diffs and mounting holes for the gears. just cant decide on which to get. Does anyone have a set or can tell me what to look for i would really appreciate it:intello:
trev3813 12.20.2008 03:53 PM
Look, for gears :mdr:
brushlessboy16 12.20.2008 05:06 PM
... Thanks. Your so helpful
BrianG 12.20.2008 05:08 PM
So, you're converting a truggy to a buggy? I guess I'm not following.
Anyway, I would just play with the numbers and get the option which gives you the most spur/pinion flexibility as far as gearing goes...
brushlessboy16 12.20.2008 07:50 PM
Im just swapping diff gears. Cen uses an odd ratio. I have it all specced out to run all buggy drivetrain. just dont know what brand gears to get
brushlessboy16 12.20.2008 09:14 PM
ALright, my setups is CC 1515, MMM, 4s lipo.
Currently i have stock cen gears( 9/26), odd ratio- and a gargantuan 66t spur gear with a 16t pinion for 41mph.
The setup i am looking at (buggy diff ratio) with a 46t spur and 13t pinion puts me at 44mph and i can use a standard RCM motor mount.
Lastly is a standard truggy gearset, i would need a 46t spur and 16 tooth pinion for 44 mph..
Does anyone have a set of buggy or truggy diff gears that they would like to sell after xmas?:whistle:
If not what gears would you reccomend? spiral cut, strait cut etc etc
trev3813 12.20.2008 10:02 PM
Spiral cut, Im no expert but thats my educated guess. :mdr:
George16 12.20.2008 10:28 PM
I have a bunch of Ofna buggy gears. They have a 43T ring gear and 13T pinion. I can also put whatever diff oil you want in there (I have from 2, 3, 5, 7, 10, 30, 50K of Mugen diff oils). PM me for pricing.
brushlessboy16 12.20.2008 10:43 PM
PM sent, I just need the gears :)
brushlessboy16 12.21.2008 01:32 AM
Found These
http://www.amainhobbies.com/product_...ducts_id/14493
18 bucks for 1 set, not too bad- they are also spiral cut. might try out a plastic spur gear.... not sure yet
