-   -   anyone successfully waterproofed? (https://www.rc-monster.com/forum/showthread.php?t=1742)
Rcbros 12.09.2005 01:20 AM
Has anyone managed to waterproof the Warrior 9920 yet?
Or if you were to what would you do? And how would you go about it?
I'm dieing to run in the snow w/ electric and nitro!
Serum 12.09.2005 02:37 AM
Daniel took care of his snowmobile i thought (waterproof maxx) don't know how he did it though..
Dafni 12.09.2005 02:42 AM
Yeah, I have a snowproof maxx. But for the winter duty I bust out a EVX/Titan setup. I don't feel like bashing through snow with a $200 ESC. And I only use cheap sport packs in the snow, too.
I once submerged a running 9918 in water... but out of sheer luck nothing got damaged, I would not try this again.
Generally my RCs stay indoors when it's wet outside. I just assembled and snowproofed a stock maxx for some snow bashing.
lipomax 12.09.2005 02:58 AM
My maxx is using the Mtroniks Truck. Totally watertight. I also have my receiver in a receiver box. almost 100% waterproff too
E-Traxxer 12.12.2005 02:34 AM
The MTroniks Truck ESC may be waterproof, but water conducts electricity, and if water touches two of the terminals for the battery or motor, it can still be damaged. I don't see how the waterproof-ness helps it, really, unless you cover up the terminals.
nbcaznmaster 12.12.2005 07:35 AM
just dont risk it, only time i did it was just 3 days ago when the ice ontop was frozen (frozen rain). So i basicly drifted my revo on a sheet of ice. Fun as hell.
MetalMan 12.12.2005 08:14 PM
That's not entirely true. Pure water won't conduct electricity, or at least well enough to cause any problems. If you through salt or something else, then it can. But this is only a problem if it were dunked in saltwater with a battery connected. I personally would never do that :L:
nbcaznmaster 12.12.2005 08:52 PM
if u run the burshless in sthe wet snow-covered street, u probably get screwed cuz of teh rock salt
E-Traxxer 12.12.2005 09:10 PM
Funny story, I remember when I was little (5 or 6) I was watching Pokemon (if anyone knows what that is) and an electric pokemon would beat a water pokemon because the water would conduct electricity and knock out the water pokmon that would be in that water. Odd source I know, but I didn't realize that I learned from that. Just goes to show that you can't trust Pokemon! I haven't taken chemistry either yet, I'm taking 11-12th grade physics in my freshman year instead. :eek:
Hmm, so it would be possible after every run to pour pure water onto the ESC to cool it? It never rains here where I live, so I don't really have to worry about waterproofing.
Cartwheels 12.12.2005 11:22 PM
I ran in snow quite a bit a few years ago with my old setup. It was a Scultze 18.61 and a Lehner 4200 on 7-8 cells. I would put the esc in a balloon, poke the wires thru holes in the balloon. This was all in a rustler with paddle tires. It would run great on top of hard crunchy snow. After a few runs there would be an inch of snow cover all of the inside. The esc and the inside of the motor would eventually get wet and quit working. Then I used to take the shrink wrap off the esc and open up the motor, put it all on a heater vent to dry it out. When it was all dried out. It would work again just like normal. I still have this setup, it's in my son's car, It's still going today and that was 2 years ago. It was a lot of fun but, a lot of work too.
MetalMan 12.12.2005 11:33 PM
It isn't a good idea to do that with a non-waterproof controller, since tap water does contain impurities that could potentially short something from the charge that could be left in the capacitors. Notice that I did put "pure" water :cool:. But if you had to, then unplugging everything first would be the best thing to do.
Is that AP physics? I don't think it would be. Freshmen year I took Biology, and last year (sophomore) I took chemistry. Right now I'm in AP Physics, and that class is quite a brainful! Next year I will take AP Chemistry and AP Biology as well.
E-Traxxer 12.12.2005 11:43 PM
Nah, if I'm already in a class with people 2-3 years ahead of me, I dont think I could handle it as an AP, already hard enough as it is.
Dafni 12.13.2005 02:48 AM
"Pure" water might not be conductive enough, but we're talking realy pure here, as in distilled or demineralized. And still, you check the purity of pure water by its conductivity. So it never is absolutely zero.
AND, even rain water (the purest water that occurs in nature) contains dissolved gases, thus it gets conductive.
Sneeck 12.13.2005 12:14 PM
Rain water pure? That I laf at. Especially when there are plane's flying near you(they fly anywhere. The unburned fuel mixxes with cloud's, creating anything but pure water). Ever tried to drink rain water? Don't.
Anywho, you can easely water proof a esc. Make a lexan box and cut all the pocket's needed for the wire's. The top has just a hole big enough to fit the cooling fin's through. Fit the esc inside the box, use silicon to seal everything. It doesn't look pretty, but it can be made to work. It's just give's a big mess when you need to swapp the esc.
Dafni 12.13.2005 12:57 PM
I said the purest water that occurs in nature, from a chemical point of view. Natures way of distilling water. The minerals stay in the sea. If you know what I mean.
But nevermind. Just don't mention rivers and the ocean.
You're definitely right about the pollution. A disgusting state of affairs.
But even without pollution at all, just dissolved CO2 (forms carbonic acid) makes the rainwater to a very weak acid....making it to dissolve limestone.
Long story short: water is conductive. Don't use your hairdrier in the tub.
