-   -   VXL Rusty w/Proline 30 Series? (https://www.rc-monster.com/forum/showthread.php?t=17425)
Fast5sRevo88 12.20.2008 08:53 PM
I want to use Proline 30 series rims and tires on my e-rusty, but as most of you know the rusty has back hexes up front instead of the stationary spindles that the Jato and nitro rustler use, the 30 series is only compatible with the Jato, Nitro rusty, and nitro pede. So my question is, could i just get 2 sets of rear jato rims and put a rear pair on the front of the rusty or would they be the wrong offset?
jayjay283 12.20.2008 09:13 PM
I run 2 sets of rear Jato Anacondas on my rustler, the offset will be "off" (not equal front and back, rear will stick out more..its not that bad but they are off unless you get the FLM extended front aarms. This company is making foams in offset for them http://www.jacoracing.net/newitems_foam_rubber.html
Fast5sRevo88 12.20.2008 10:28 PM
Ok, that is helpful for sure. I really want some of those Jaco's for aspault, but i do see alot of offroad so i do need some 30's for that in Dirt Hawg tread. I could use some flm extended arms up front, they would also double as a wheely counter-weight:lol:.
skellyo 12.20.2008 11:47 PM
The FLM front extended arms make it perfect for the 30 series:
http://skellyo.com/vxl_rustler/30badlands1.JPG
http://skellyo.com/vxl_rustler/30badlands2.JPG
4u2nv 12.20.2008 11:48 PM
Why not just switch the front over to the Nitro setup with the spindle. That's what I did on mine.
Gee 12.21.2008 09:33 AM
I did the same thing with my rustler. They are stronger then the setup the rustler uses. I sure don't miss all those bent king pins I use to have change out.
Arct1k 12.21.2008 10:09 AM
Ditto with my pede... you can use the 17mm jato adapters then...
http://i168.photobucket.com/albums/u...k/Pede/036.jpg
Fast5sRevo88 12.21.2008 03:17 PM
I'm assuming ya'll used the spindle setup from the Nitro Rusty?
Fast5sRevo88 12.21.2008 04:03 PM
It looks like u also have the standard length FLM arms on the back? And of course the extended ones up front.
