-   -   WTTF: A truggy or buggy or spektrum system... Check it out! (https://www.rc-monster.com/forum/showthread.php?t=17441)
BL_RV0 12.21.2008 06:18 PM
I'm looking for another 1/8 truggy and here is what I have to trade for it. I will get pictures if you are interested in anything.
Here is what I have.
Complete MGT with .21 engine, chevy body, and new stock wheels and tires.
Does not have servo or TX/RX. Has aluminum steering system, titanium front bumper, piggyback shocks and aluminum turn buckles.Also comes with enough parts to build another truck sans an a-arm and chassis. I would be happy to not include the engine if you don't want it.
Mini-T roller, needs some TLC. has all stock electronics except battery, but I don't know if they work or not. Also has a 380 motor.
23mm adapters for a t-maxx or other 14mm hub truck.
23mm wabash 40 series rims mounted on road rage tires with 85% tread.
LST wheels and tires.
Stock Hyper ST wheels and tires. (very lightweight, only 190gr apiece)
One of takedown's 6 cap boards.
Hitec HS-645MG servo.
Hitec HS-625MG servo.
Futaba S3002 servo, 2 of the 4 ears are broken off.
2 brand new Futaba S3003 servos.
New Dremel Stylus.
Proline 23mm wrench.
JR XR2i radio system.
RCM 16t pinion.
Hitec DCX FM 75mhz 3ch RX.
Hitec HFS-03MT FM 75mhz 3ch RX.
Duratrax RX-301F FM 75mhz 3ch RX.
Tekin TFM 27 FM 75mhz 3ch RX.
That's what I have. PM me with what you have. Thanks!
