-   Novak (https://www.rc-monster.com/forum/forumdisplay.php?f=42)
-   -   Help! (https://www.rc-monster.com/forum/showthread.php?t=17460)
Brushless Moose 12.22.2008 03:30 PM
Help!
I was running a novak HV 6.5 pro system in my E-Revo, when it suddenly acted like it had a really strong drag brake. first thing I thought was that there was binding in the drivetrain, so I rolled the revo, and it was hard to push.I pulled the motor, and it rolled smoothly.When I throttle the motor outside of the vehicle, it barely revs up, and acts like it is binding somewhere. It gets hot REALLY fast, then smells bad. When it does this, I make sure not to let it get above 140.When it was in the vehicle, and running fine, the temps were 110-115F. What happened? Novak CS is closed until after Christmas. PLEASE HELP ME!
BL_RV0 12.22.2008 03:49 PM
Sounds like your windings are shot.
TexasSP 12.22.2008 04:56 PM
Bad windings or bad magnet. Take the motor apart and inspect.
lincpimp 12.22.2008 05:59 PM
You most likely have a short between the phases. Must have overheated it somehow, or something came loose inside the motor. I would send the whole system back to Novak. The esc may be damaged too...
