-   -   Wanted - Small project box... (https://www.rc-monster.com/forum/showthread.php?t=17478)
Arct1k 12.23.2008 11:19 AM
Can anyone recommend a small project / rx box that will fit a MM - I'd like to mount my MM's on the front of my clod but they must be boxed for rollovers etc...
thanks
BrianG 12.23.2008 11:20 AM
RadioShack, allelectronics.com, etc
Arct1k 12.23.2008 11:22 AM
Can anyone validate the measurements - ESC overall: 1.9" x 1.3" x 1.2"
I checked radio shack online but nothing looked suitable...
http://www.radioshack.com/family/ind...ion=1&x=14&y=5
BrianG 12.23.2008 11:40 AM
It might be tough to find a box that will be the perfect size for the ESC. Plus, the RS enclosures have internal posts for the lid screws and raised grooves for PCBs. The posts and grooves can be dremeled out, but then you have to find a different way to keep the lid on.
I've also modified those boxes if too long by cutting a section out with a miterbox and then glueing the halves together. Not too pretty though.
You could also make your own out of lexan/plexi.
Arct1k 12.23.2008 12:05 PM
http://www3.towerhobbies.com/cgi-bin...?&I=LXBMA0&P=M
http://www2.gpmd.com/image/a/ascc2258.jpg
SPECS:
Length: 56.7mm
Width: 40.3mm
Height: 30.3mm
This one looks a goer - Will try to measure it up tonight...
What's_nitro? 12.23.2008 12:25 PM
That one should fit it. The heatsink might rub on the lid, but I suppose you would make a cut-out to allow for cooling anyways.
Arct1k 12.23.2008 12:34 PM
Only running in a crawler so not too worried about heat - I was thinking about mounting esc on side so close 1.2" = 30.5mm...
The idea is to protect it so don't really want to expose caps or sink...
What's_nitro? 12.23.2008 12:36 PM
But isn't the 1.2" from the bottom of the case to the top of the HS? You'd be putting the 1.3" side in the 30mm space.
Arct1k 12.23.2008 12:52 PM
I havn't got one in front of me but assumed 1.2 was width and 1.3 height... If 1.2 is height of caps it will be a touch snugg - Might be able to dremel the box a bit..
But you now have me wondering if internal or external measurements... lol
What's_nitro? 12.23.2008 02:05 PM
That's true...they don't say which. :grrrrrr:
TexasSP 12.23.2008 02:14 PM
Try a hitec servo box. I see many of the guys on rccrawler use them.
johnrobholmes 12.23.2008 02:28 PM
I doubt you are going to hit it unless you are mounting it waaay up front and high. Like on a stick :lol:
