Hyperion dimensions.
http://www.rc-monster.com/proddetail...d=HP-LVX43505S
Anybody have the dimensions of the pack linked? Thanks. |
47mm x 160mm x 39mm
Thank you. Noticed you have a D8, does it fit under the body in Mike's battery tray?
I actually am in the process of building the D8 at the moment, so I can't answer that quite yet. :wink:
Ok, thanks again. I'm just wondering if the 4350mah 5s would give me the same run time as the 6000mah 4s if I gear down two teeth on the pinion.
The 15 tooth on 4s is good, but could use just a little more top end and a slightly cooler temp. |
| All times are GMT -4. The time now is 12:05 AM. |
