-   -   BL WheelyKing! (https://www.rc-monster.com/forum/showthread.php?t=17628)
emaxx 101 12.28.2008 05:07 PM
BL WheelyKing!
3 Attachment(s)
Hi everyone, I finished my second BL project about a month ago, a BL Wheely King. I get speeds of 35-40 mph, 40 minute runtimes and it runs cool. Its a Blast! :party:
Parts Used:
MM 6900kv Combo
Hpi Heavy Duty Differential gear
Team Orien 3900mah 6-cell rocket pack
RC4WD Stainless steel turnbuckels
Hpi 23t pinion
Hpi 93t spur
Heres a Link to a vid of it's balooning tires:http://www.youtube.com/watch?v=t3nS0...e=channel_page
http://rc-monster.com/forum/attachme...1&d=1230498316
suicideneil 12.28.2008 05:14 PM
40mins with a 3900mah rocket pack? Im impressed.
Only thing I would suggest is to slam the suspension some how (longer links or shorter shocks, or both), and that will make it handle the high speed alot more stabley.
pedeboi364 12.28.2008 09:12 PM
... i hate u... y the 6900? im guessing the wk is light and the 6900 on 3s would rip!! HA!! 3s lipo here i come. bl system FS/FT!
emaxx 101 12.28.2008 10:10 PM
The 3s wont fit in the Wk's battery compartment so i chose a 6900 instead of a 5700.
pedeboi364 12.29.2008 12:14 PM
so the 6900 won't take 3s? How hard would it be to modify the batt. tray to fit 3s? I plan on using a Zippy 5000mah pack from hobbycity (the blue one)
emaxx 101 12.29.2008 02:20 PM
Modding the tray would be pretty hard, as you would have to make it longer and thicker, thus having to move the transmoission, electronics back (very hard). The second alternitave is to thicken the tray, then extend it out past the cars frame. The 6900 with 3s would give you around 76,000 motor rpm, I wouldn't suggest that. Already, my cars speed is crazy, but it could have better handeling. Like Sucicideneil said, it would handle better with shorter shocks. If you want speed, i would recomend staying with a 6-cell nimh or 2s lipo and using the 7700kv motor, or castle's new 9000kv motor, all with an rpm limit of 100k. 3s or 2s, you should use all heavy duty gears, as I found out the hard way.
pedeboi364 12.29.2008 06:32 PM
from what it looks like I'll be running a BK ESC with a fiegao or CC motor. I still have a high quality 4200mah 6cell pack that i use now, and i don't plan on selling it unless i really really need $30 lol
