will these fit crt .5
Yes they will! The slash has 12mm hexes. I run stock slash tires on my .5 and they're decent so I'm sure these are even better for all around bashing tires
Ty for the quick reply. I am debating between these and the little more expensive eritex Beadlocks. I was thinking about calling them tomarrow and seeing if they would custom a set of these in a 2.2
http://eritexinc.com/zencart/index.p...&products_id=3 Those with a black wing, white body would be really nice. Do you have any problems with the crt .5 weak spots ect? |
Hit a dumpster once and nothing broke. Barrel rolled it a few times doing high speed passes in single digit temps and broke a front a-arm and turnbuckle. Pretty solid truggy. The bigger tires put a bit more stress on things and thats what I was using when it broke.
The eritex are heavy and designed for crawling - they will put a lot of stress on driveline i,.e. expect breakages.
Get light wheels... |
ty for the heads up
| All times are GMT -4. The time now is 11:35 PM. |
