4s MM
Hey guys. Im planning on using an MM in my T-maxx and stampede, 4s and 2s configs. I think ill run an 8xl in the T-maxx on 4s, so i was wondering what mods ppl r doing to run 4s on their Mamba Max's. thnx!!
Just remove the red wire.
On 4s, I would also run a ccbec...
i plan to run a ccbec, i 4got to mention. which red wire brianG??
I would read my Emaxx FAQ and skip to the parts about BL and esc modification...
Brian's website explains all you need to know with regards to wiring- you need to take the redwire out of the rx lead to disable the built in BEC. |
You'll need a heatsink and/or forced cooling with an 8 turn, maybe consider a 9XL and gear higher. I have run my MM successfully for almost 6 months (in a 14.4 pound truck) with no mods other than disconnecting the internal bec, (I use a receiver pack) and adding a fan to the MM, just so I never get thermals.
hmm, so i should shoot for the or 10 xl?? i have the perfect setup idea regarding the red wire, but are the servo plugs/connectors easy to find. i wana shorten the MM lead, then be able to use 2 diff extensions (with n without red wires) to work differently between my T-maxx and pede. So im getting that i dont need to install a cap? what rx packs would u guys suggest for a T-maxx??? thnx!
Personally I always add an extra cap - I had two blow up without caps - since adding caps all of mine have been fine... no other changes...
If it helps mike adds the extra cap to - it is only a $4 mod... |
the extensions work well.
i wouldn't use a rx pack, i'd use a bec. i'd add a cap, here's one http://www.rc-monster.com/proddetail...=35vcap&cat=21 |
so take out the internal bec and use the ccbec??also, where do i add these caps??
Close the esc as possible on the power lines...
Strip off a small amount of insulation about 1cm back from ESC on battery wires and solder in cap leads - again keep them as short as possible. |
so i taps into the ESCs batt leads? should i take the cap off when using only 2s in my pede? do i really need a 10a bec? any others that r a bit cheaper? thnx
do you already have the esc? if you dont. i suggest just getting a mmm. you will end up spending just as much getting a mm ready for 4s when you could already have a mmm for the same price.
$35 and a good amount of space would be wasted. it'd have fit in my pede, and i would be tempted to go 6s
| All times are GMT -4. The time now is 04:41 PM. |
