What is best servo for CRT .5?
Well I bought a crt .5, when I purchased it I was under the impression that the extended chassis that is installed would accept a 1/10 servo...no such luck. Now I need a servo that fits. Something that is best bang for the buck and good performance.
I know I could drill the chassis but I would like to run this thing to see if I even like the way it feels before drilling on the new chassis. BTW I am running a Team Blue Groove chassis and conversion. Thanks guys. Paul |
The extended OFNA and mikes chassis does enable a full size servo...
Otherwise in the mini's this is about it... http://servocity.com/html/hs-5245mg_digital_mini.html Or I have one of these for sale... http://servocity.com/html/hs-225mg_mighty_mini.html |
Well I would say support RC-M and ditch the blue groove conversion! The blue groove opens itself up to gear mesh problems as it mounts the motor the same as a nitro motor. RC-M's mount holds the motor solid to the center diff eliminating the chance of chassis flex changing the gear mesh. You can order an OFNA extended chassis conversion and run a full 1/10 servo or get the RC-M chassis that is even longer and allows full size servos. Otherwise your very limited in servo selection. However it doesn't take much to turn the little wheels. I'm only running a Spektrum z590 that I paid $30 for and I have no complaints with it's speed or power!
PM if you want an ofna .5 extended chassis for a few $'s...
I have my old one from when I swapped to mikes... |
I went and picked up servo today that fits. I am not really trying to spend any more money then this right now....my real funds are going into my 8ight. Thanks fo rthe suggestions guys and I will post how it goes.
BTW I bought the truggy with the kit already installed. I wouldnt have choosen this one but the price was right on this un-ran set-up. |
| All times are GMT -4. The time now is 03:35 PM. |
