-   -   Help with MRC power supply and Hyperion 0606i (https://www.rc-monster.com/forum/showthread.php?t=17763)
Big House 01.02.2009 06:00 PM
I am getting a voltage error from my 0606i meaning it is not seeing enough power or to much. How can I resolve this issue if possible?
fsracer 01.02.2009 06:06 PM
Is it an input voltage error or an output voltage error. What is the power suupply voltage for that model 13.5vdc or 15vdc.
Big House 01.02.2009 06:35 PM
Input..and the manual states it accepts 11 - 15 volts.
fsracer 01.02.2009 07:18 PM
I'll assume that all your power wires are soldered properly positive for positive, did it ever work properly or is this the first time being plugged in. I have had this problem then it went away, are there connector between the power supply and the charger they may need to be checked, don't over heat the wires when soldering.
