-   -   EZrun (https://www.rc-monster.com/forum/showthread.php?t=17767)
pedeboi364 01.02.2009 07:28 PM
EZrun
Anyone know...
how reliable they r
if they can be run with a CC4600 or 9L motor
how many cont. amps i should get to run in a pede and mt2 on 3s
what they cost
THNX!!!!
pedeboi364 01.02.2009 07:39 PM
would 60a work?? i need this info ASAP
pedeboi364 01.02.2009 09:13 PM
what kv should i run in an mt2?
suicideneil 01.02.2009 09:26 PM
Are you a gambling man?
I've seen a revo running the 60amp version on 4s lipo; wou;dnt try that myself, but it did run perfectly fine.
Given the price though, I really would just buy an mambamax- wouldnt like to guess what kv to use, but there are other similar conversions around here, plus its easy enough to figure out once you know the diff and tranny ratios etc.
pedeboi364 01.02.2009 09:42 PM
staying cheap is my goal, and i only plan to use it to power a pede and mt2 on 3s. 120 for the combo and extra motor is unbeatable
azjc 01.02.2009 10:09 PM
you could run a 60 amp ESC if you are running at least 8s......
pedeboi364 01.02.2009 10:24 PM
...i dont have that kinda room, but would a 60a system on 3s push a pede or mt2 well or should i look into the 80a version??
azjc 01.03.2009 12:12 AM
I had a MM in a Rustler on and its a 125 amp esc, go more than what you think you need
pedeboi364 01.03.2009 09:20 AM
i have a novak SS and LRP 8.5t motor and i get rolling wheelies at 5mph on my bald talons. I found a combo with the 60a ESC and 2 yeahracing 3300kv motors and the programming box for 120 shipped. R those motors to low of a kv for the pede and mt2? I know the VXL is 3500kv, but thats pretty low to start with, and the motor i have now is 5800kv. Would i just need to regear? Lastly, ive heard all good things about yeahracing lipos, any1 know what their motors r like?? thnx
azjc 01.03.2009 11:17 AM
you get good speed with the VXL and 3s I have a VXL Rustler on 4S (but thats a different story) and using a 40 tooth Revo spur and a 16 tooth Mod 1 pinion and I had to remoce the gear cover to make this fit but that is no problem
pedeboi364 01.03.2009 11:30 AM
ya, i dont feel that speed hungry, cuz down time sucks. Arg, the ESC i am running (SS, similar to the havoc) is rated for 120a, but i can only run 2s. I guess its the 60a system i found (includes 2 motors and programming box) vs. the VXL system
