motor conector and mamba monster
just wanted to know,does the mamba monster esc come with the 6.5mm connector male and female already soldered on with the wires? because i have mine on the way,dont know if i need to buy any.just want to be prepared.thanks.
The Upgraded V2's come with bullets, the "real" v-3's come with wires
combo or just the esc? The combo has a longer motor wire with the male bullets already attached. If it's just the esc that you have coming they come with 3 wires about 6" long that have the 6.5mm male bullets attached to one end and the other is bare, either solder directly to your motor or use another set of bullets(not included)
My monster came with 6.5mm on motor wires now the battery wires I soldered on 6.5 can't remember if it had a connector.
yes it is just the esc.and i guest it does not come with the battery wires right?
and what gauge wire is that? |
It does come with battery wires- either another pair of 10gauge (to answer your other question) wires with 6.5mm bullets on one end and bare at the other, or the wires directly soldered to the esc (with bullets on the tips I think).
I wouldnt worry too much, you'll soon see how many connectors and what type you need/want for your setup once the esc arrives. |
For the esc only, you will get the following:
5 10 ga wires (2 red, 2 black, 1 white) 2 5mm caphead screws (for mounting motor to motor mount) 1 set of 6.5mm bullet connectors (3 ales, 3 females) DVD CC Link Instruction book None of the connectors were soldered on mine. I have to solder them myself. |
| All times are GMT -4. The time now is 08:17 PM. |
