-   -   Priorities (https://www.rc-monster.com/forum/showthread.php?t=1778)
captain harlock 12.12.2005 04:00 PM
Priorities
If I'm going to use a motor like a 9xl what are the prior things I must change in the E-maxx truck. 18 cells are my choice.
sleebus.jones 12.12.2005 04:02 PM
From what I've been told:
Steel idler in the tranny
Strobe Slipper
CVDs all around
Sleebes
E-Traxxer 12.12.2005 04:14 PM
Strobe Slipper
CVDs all around
Sleebes
That should hold up fine, but if you want a bit more protection, you can get aluminum diff cups, the stock plastic ones are weak.
squeeforever 12.12.2005 04:23 PM
i would go for the flm hybrid bulks. they are MUCH stronger with the 1/8th gears and you'll find the stock bulkheads are a very big weak point on the truck.
captain harlock 12.12.2005 04:33 PM
Seems good so far. you know where I can get a strob slipper kit beside here? ( its out of stock).
squeeforever 12.12.2005 05:05 PM
check mike, he should be able to get them in no time.
squeeforever 12.12.2005 08:05 PM
looks like your in luck. there back in stock.
nbcaznmaster 12.12.2005 08:10 PM
lol, wut luck. you should still e-mail mike just to onfirm if anythign is outta stock. I wanted deans wires but it was outta stock, foudn out there was \still a bunch. Mike fixed the site right away.
captain harlock 12.13.2005 06:16 AM
What's the use of the strobe sprong kit?
Sneeck 12.13.2005 11:59 AM
Won't need plyer's to adjust the tension against the slipper plate. Instead of a locknut it's a big ring and instead of the metal spring it's a rubber block thingy, thus the name sprong.
captain harlock 12.13.2005 03:13 PM
Is it really important to have it?
Sneeck 12.13.2005 03:19 PM
Not really, but it is very usefull to quickly adjust the slipper plate presure.
captain harlock 12.13.2005 03:45 PM
Great. I only need to sell my things befor I start my e-maxx project.
nbcaznmaster 12.13.2005 05:21 PM
wut type of things/????lol
E-Traxxer 12.13.2005 05:22 PM
It's not only useful, the material used in the sprong retains it's shape very well and applies pressure evenly, unlike the spring, therefore the spur gear does not wobble compared to the spring setup.
