-   -   Need new wheels and tires for maxx truck. (https://www.rc-monster.com/forum/showthread.php?t=17781)
A RC Dude 01.03.2009 04:33 PM
I'm looking for all-terrain tires and wheels with 17mm hexes. I'll also need 17mm hex adapters. I'm looking for something a little ligher than the stock tires and i don't want the tires to be mostly rim.
If you guys have any sugestions, it'd help a lot! Thanks!
emaxx101 01.03.2009 04:48 PM
badlands.
E-Revonut 01.03.2009 05:01 PM
Badlands MT! Just make sure to clean the inside of the tire with rubbing alcohol and tape them, otherwise they get a bit crazy after 25MPH. For rims use Maximizer beadlocks and OFNA/HoBao 17mm hex adapters. Great combo, many of us are using the same thing on here
A RC Dude 01.03.2009 06:06 PM
Are these the right adapters?
http://www3.towerhobbies.com/cgi-bin...?&I=LXTUY0&P=7
Would the maximizer 17mm adapters be any good?
and about how crazy are the badlands compaired to the stock maxx tires over 25mph?
wallot 01.03.2009 06:52 PM
ofna 17mm adapters, jconcepts rulux wheels and badlands
lincpimp 01.03.2009 07:20 PM
Badlands are the best all terrain tire I have found. I use maxximizer beadlocks, and balanced the whole assy. The duct tape on the inside of the tire is a must. Onne wrap with about 1" of overlap will do. I use the clear heavy duty 3m stuff, seemed a bit lighter than std grey duck tape, and still had all of the string stuff in it. Plus it was super sticky. This combo will be a bit heavier than a stock tire, but will last longer and perform better.
One more suggestion... Molded foams are a good investment as they last longer and work better than std forams. If you are using beadlocks they are not really necessary but I prefer to not have to change foams before the tire is worn out...
A RC Dude 01.03.2009 07:39 PM
ok thanks again linc!
lincpimp 01.03.2009 07:48 PM
No prob, have fun!
A RC Dude 01.15.2009 09:33 PM
got them sunday when i got back home. got everything togather and it looks good! Like the wheels! But the bead-loc's are hard as heck to get togather
