need tire opinions on glue and rims
so i just got my ebay auction, duratrax warhead stock tires, and proline road rage tires with half offset rims. http://cgi.ebay.com/ws/eBayISAPI.dll...m=220335715421
the road rage's have off set rims, the duratrax don't. all tires were barley glued so i removed them from rim. the rims are almost brand new, the chrome isn't even flaking. Question is should i keep the road rages on the offset or use the offset rims the offroad tire? also for tire glue anyone try http://www.gorillaglue.com/glues/superglue/index.aspx it say impact strength:lol: or is tire specific super glue really that much better (shock resistant) and what not also do you know what brand the blue rim is? lastly is 13.6 oz heavy for a monster truck tire w/ rim and foam ? sorry for question purge thanks |
i would advise using the medium thickness super glue main cuz they will come off clean when you boil them to change tires. Not sure if gorilla glue will
Only dudes I know who make blue rims are RPM. I dont know the glue from experience but I heard it turns brown and takes a turd after a few weeks.. get some thin super glue. $4 cant go wrong
for the thin or medium glue recommended is that just any CA or tire specific
. and what makes tire specific glue any better or is it just CA labeled for my ignorance :lol: |
as I understand it(my educated guess) super glue is ca glue, and isn't tire specific. I have used super glue and ca tire glue interchangeably and gotten the same results.
gorilla glue, silicone, anything you want will hold a tire on, with ca or super glue tere are ways to get the tire off |
Skip the glue and get a set of beadlocks!!! I don't know if I'll ever run glued tires on my MT ever again!
I run silicone with my beadlocks. I've tried pro-lines, axials, and maximizers, and like maximizers the best, but have still had the bead pull out in spots. The silicone gives a little extra hold and cleans up fairly easily.
| All times are GMT -4. The time now is 12:15 AM. |
