-   -   Starting a Swift 2 brushless conversion (https://www.rc-monster.com/forum/showthread.php?t=18013)
harryf1 01.13.2009 01:42 PM
Hi, i am in the process of converting my nanda racing swift 2 1/8 buggy (don't laugh!) to brushless. What motor/esc/battery/pinion configuration would you recommend? If it helps, i would like to go at least as fast as the buggy was when it was stock nitro so around 50mph, the wheel diameter is 33cm and my buggy will weigh about 3kg when completed.
Thanks.
harryf1 01.13.2009 03:29 PM
i will also be designing/making my own motor mount and center diff plate to match the motor/esc
dirt101 01.13.2009 05:09 PM
just so you know the stock probably went around 37, but anyways I would go with the caslte neu 2200k/v combo, a zippy 5000mah 4s lipo, and for gearing you can use this
harryf1 01.13.2009 06:03 PM
ok thanks, what would you recommend as the max amount of teeth i could get away with on the pinion with the standard 46T spur without the motor overheating?
suicideneil 01.13.2009 07:15 PM
Use the gearing calculator in that link- just enter your diff ratios and tire sizes etc, then find a pinion that gives you ~40mph with your 46t spur.
What heck is a Swift 2 1/8 buggy anyway- pics/ link required.
anson 01.13.2009 07:39 PM
I want to see these 33cm diameter wheels! Did you mean circumference?
http://www.racing-cars.com/products....cnumber=15909# Is that it?
hailmick 01.14.2009 12:44 AM
i think he means inches
and thats the buggy alright
one company makes the chassis then they are redaged by about 3 resellers
harryf1 01.14.2009 02:59 AM
yes sorry i meant 33cm circumference and yeh it is that buggy. I've had it about 3 years. Thanks for all your replys, i'll post pics etc up of the whole build once its complete.
dirt101 01.14.2009 05:02 PM
I would gear for about 38mph. My truck is geared for 42, and its just a little faster than I would like it.
that buggy looks sweet...I love the purple and carbon look.
harryf1 01.14.2009 05:26 PM
yeh it is a very nice buggy to look at. After much deliberation i'm going to go with the 2650kv monster combo! i can't wait!
harryf1 01.18.2009 03:33 PM
here's some pictures:
http://picasaweb.google.com/harry.bu...at=directlink#
not bad considering it's 3 years old and very well used.
