-   -   CastleNue Motor screws?? (https://www.rc-monster.com/forum/showthread.php?t=18019)
YogyBrushless 01.13.2009 05:01 PM
hey guys i have questions about the castle motor combo, what are the 2 screws that came in the box ? are they motor screws? and if they are not, what size screws should i get ? because they are good for my tekno conversion mount for the revo they fit , but for TDracing mount for the LST2 they dont even reach the motor through the mount.
please guys help me out with this.
Yousef
George16 01.13.2009 05:06 PM
They're the motor screws. You can try M3x10mm for your LST2.
YogyBrushless 01.13.2009 06:09 PM
i measured the screws that came with the combo they are m3x5mm (measuring the diameter and the thread not the cap head) and i then measured the black front end cover found it to be around 4mm thick so im thinking an m3x8mm or m3x9mm would be sufficient to hold the motor. what do u think ?
BrianG 01.13.2009 06:41 PM
Simply add the motor front end thickness (~4-5mm) and add in the thickness of whatever mount you are using.
Actually, I insert a really long screw into each hole and gently turn the screw in by hand until I feel resistance (the coil). Then, I back out a turn or two and then mark the screw threads where they go into the can. Repeat for the other 3 holes and use the shortest measurement.
bruce750i 01.13.2009 06:47 PM
Just don't over penetrate her. ^^^ +1 ^^^
brushlessboy16 01.13.2009 07:35 PM
Impossible. the screws wont hit anything. The motor is designed to protect the windings.
http://i152.photobucket.com/albums/s...%20FRE/CCN.jpg
BrianG 01.13.2009 09:11 PM
Only in the Castle Neus...
YogyBrushless 01.14.2009 04:44 AM
i`m going to try m3x12mm, because my mount is 7.5mm thick add 4-5mm for the front end cover 11.5-12.5mm screw will be required. and a guy that uses the same mount and motor told me he using m3x12mm they fit.
thanks for the info guys
yousef
brushlessboy16 01.14.2009 01:11 PM
He's running the castle neu...
