-   -   Slash Question (https://www.rc-monster.com/forum/showthread.php?t=18044)
plaviblue 01.14.2009 11:24 PM
Slash Question
Is anyone using differential fluid? If so which weight works the best....just bashing.
With the brushless motor the slightest turn breaks the wheels loose.
What's_nitro? 01.14.2009 11:27 PM
Haha, I went right up to 100K in mine just for that reason! It's a bit too heavy though, as I have trouble turning sometimes. I'd say 50-70K would be better.
BrianG 01.14.2009 11:41 PM
The "proper" thickness fluid will leak out unless you mod the diff to seal it. By "proper", I mean the right thickness for normal driving.
plaviblue 01.14.2009 11:44 PM
I posted this just before I read through the slash thread....read before you speak:oh:
Thanks guys!!!
What's_nitro? 01.14.2009 11:45 PM
Oh, I forgot to say I run Flat Irons on my Slash which are larger than stock. If your tires are stock size then I'd say 20-50K.
plaviblue 01.14.2009 11:52 PM
Do you have problems with the front tires rubbing the chassy?
plaviblue 01.14.2009 11:54 PM
I saw how to this on the overpowered slash thread.....thanks Brian!!!
plaviblue 01.14.2009 11:58 PM
What is the difference between the 50 and 60 series Medusa motors? I cant seem to find the info.
What's_nitro? 01.15.2009 12:03 AM
My tires will rub a bit when I land a jump, but not when I turn.
The 60mm Medusa is longer, and so can produce more torque. The 50/60mm are good for 1/10 scale, or 1/8 buggy. The 70/80mm are good for fast 1/8 buggy, or MT (1/10 or 1/8)
