Where to go from here?
http://farm4.static.flickr.com/3373/...dbcca183d4.jpg
http://farm4.static.flickr.com/3101/...8084fed547.jpg I'm looking at about a thousand to spend from here. I still need to buy the brushless system, batteries, charger, etc... It has maximizer 7075 diff cups with RRP 3mm modified gears, MIP's all around... except for the rear, which are on order. Hopefully the 3.3maxx versions fit, the Revo's didn't. I'm looking at running 2 NeuEnergy 2S 5000 packs, and using the Hyperion 610I charger... I'm looking for roughly 40~43mph with the stock diff setup. I've been looking at the MMMv3-2200, the Losi Xcelorin with 2100KV motor, or... well, I need some suggestions. I wish Mike would mass produce the FLM direct drive unit, it would help my gearing options out. Anyways, any opinions here would be beneficial to this guy. I've been wanting to convert it over to brushless/Lipo for a while now. She used to look like this, with all the brushed nonsense... http://farm4.static.flickr.com/3086/...bdff3a9c38.jpg |
Looks nice. I am partial to the Neu or Castle Neu 2200Kv motor with an MMM esc or the MGM esc on 5s.
^^^+1 Good choice. Like the black chassis.
Man, the first thing you should've done is get a BL system. At least get a pair of lipos. I say lipos the brushless unless your nimh's are really nice and you'll miss them.:whistle:
youve got it figured out get the MMM combo, those nue packs or the rcm 2s' and gear for 40 and you should be golden, i dunno how well the diffs will hold but other can help you fix that problem.
| All times are GMT -4. The time now is 04:53 AM. |
