Best chassis for 4 batteries packs?
Which E-maxx chassis will fit better 4 batteries packs (6 to 7 cells)?
Fast Lane`s seems has bad battery straps and two packs should go in the bottom of the chassis, a little dangerous I thing. Dynamite`s only fits 6 packs. Would be Gorillamxx the best? |
Johnnymaxxima uses the gorillamaxx chassis and puts two battery packs on each side for his dual brushless set up. What is it for? Do you have a dual brushless set up?
Is for a BK3695 + Feigao 12XL setup.
In the Gorillamaxx the battery packs are over the chassis or 2 over and 2 bottom? I donīt like the batterie bottom of the chassis, maybe is dangerous. |
yeah i wouldnt put my batteries on the bottom of the chassis either. With the gorillamaxx chassis you put them all on top, two battery packs on each side one on top of the other. So your going to run your 12xl on 24-28 cells! Do you already have the battery packs? cause all those batteries will weigh a ton and you'll need some hard suspension. you could go lipo?
If you having matching cells. I would run the 7on bottom and 6 on top. It will stay better and fit better. I think the gmaxx would work better for this. Just my opinion. It is going to be some weight though. Let me know how this works out and run time you get.
Thanks for the ideas!!!
you can pack up to 15 cells each side on a gmaxx chassis. 30 cells.. Hmmm.. not bad....
| All times are GMT -4. The time now is 06:27 AM. |
