-   -   VID: my Hyper 7 w/ 70mm medusa (https://www.rc-monster.com/forum/showthread.php?t=18162)
sleebus.jones 01.19.2009 10:48 AM
6S A123 and 1600kv medusa.
HD version here: http://vimeo.com/2881341
Or click below for SD. I recommend the HD version though. ;)
<object width="500" height="281"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=2881341&amp;server=vimeo.com &amp;show_title=1&amp;show_byline=1&amp;show_portr ait=0&amp;color=00ADEF&amp;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=2881341&amp;server=vimeo.com &amp;show_title=1&amp;show_byline=1&amp;show_portr ait=0&amp;color=00ADEF&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="500" height="281"></embed></object><br /><a href="http://vimeo.com/">e-Hyper7 at Stephen F. Austin state park</a> from <a href="http://vimeo.com/sleebusjones">sleebus jones</a> on <a href="http://vimeo.com">Vimeo</a>.
Metallover 01.19.2009 11:03 AM
Nice! That system must run really cool.
ssspconcepts 01.19.2009 11:04 AM
Cool video...that thing is quick!
Sower 01.19.2009 11:07 AM
Very nice. What made you go with the 70mm can vs. the 60mm?
sleebus.jones 01.19.2009 11:19 AM
Because too much power is just right! :mdr: I love torque, and I also figured that a bigger can will run cooler than a smaller one. I don't like to push my stuff if I don't have to. Sumertime down here in Texas can be brutal, and as a result I design my rigs to run cool so I can play anytime I want to. That setup there with me running around is maybe hitting 120 - 130. That's only running on grass, I expect it to be cooler on a track where it's not in a high-amperage situation all the time.
As it is (15/46) it runs great, is controllable, runs cool and has wicked acceleration. I think the runtime is at least 15 mins, probably longer. I haven't timed it yet. Definitely going to have to get out to a track now.
Raze ST Truggy 01.19.2009 11:21 AM
That video was awsome in HD. You've got a reall nice running buggy there. I have the 80mm 1600kv medusa on order and I can't wait to try it in my truggy or muggy.
-Brian
magman 01.19.2009 11:54 AM
Sweet vid.
Maciolus 01.19.2009 03:26 PM
15 minutes? I am impressed :) I understand you are running 6S2P A123.
Nice vid BTW :)
killermmn 01.19.2009 03:54 PM
not bad sle!!
i will buy a 80 mm 2200kv for lst2 for sure!!
sleebus.jones 01.19.2009 04:28 PM
Nope, 1P.
Maciolus 01.19.2009 04:36 PM
OMG :surprised:
I am running similar setup HB L2PE buggy, Medusa 36-60-1600 14/46 and have 8 min runtime...
What's wrong with my setup? Should I use bigger pinion?
Metallover 01.19.2009 04:38 PM
I think jones may have been a little light on the throttle.
sleebus.jones 01.20.2009 11:38 AM
Originally Posted by Maciolus (Post 253752)
OMG :surprised:
Really hard to tell. Driveline drag? Different motor size? I'm not sure I can pin this one down for ya.
That, my good man, is unlikely. :)
Sower 01.20.2009 11:41 AM
OMG :surprised:
A bigger pinion will probably shorten your runtime - if anything, try a smaller one.
Maciolus 01.20.2009 03:06 PM
I feel it is undergeared.
Gearing is not that obvious with four pole motor :wink:
I will check it with ET.
