Revo Mod 1 Spur
Anybody know where I can get a Mod 1 spur that is compatible with the stock revo/maxx slipper and that is also larger than 40T? 51T is really what I'm looking for but cant find one that will fit on the stock revo slipper.
Anybody have a workaround? |
Revo spurs are titchy yeah- the most common work around is to use something like MGT spurs I believe, they have a 51t spur thats MOD1. At worst you just have to enlarger the holes slightly for the screws to fit that bolt it to the slipper plate thingy.
If you don't mind using 32p, Jato spurs work. IIRC, maxx and the E-Revo use 32p system on the Revo style slipper as well.
If you want specifically mod1, then modifications will be necessary. Or, see if Mike could make an adaptor to allow you to use your 51t spurs... |
MGT Mod 1 spurs are your best bet. They come in 46,47,49,52T. Tower has them.
What about a savage slipper assembly? Has anybody tried one of theses? Seems like this woud work fine:
http://cgi.ebay.com/HPI-SAVAGE-X-XL-...QQcmdZViewItem My problem is this: <table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/6C1uOdWZ1xhpyCnInLAu0Q?feat=embedwebsite"><img src="http://lh4.ggpht.com/_Go2PcH5NPr4/R9HsW2S_kZI/AAAAAAAABl0/t-kca8ar9fg/s800/IMG_2158.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/ssspconcepts/Revo?feat=embedwebsite">Revo</a></td></tr></table> My motor "bottoms out" on the tranny case before the gears mesh together. I guess I could use like a 25T pinion:oh::gasp: But I don't think that would mix well with the electronics. I was thinking that since the savage slipper also rides on a 5mm input shaft that it would be a fairly straight forward mod. |
The MGT spurs work great with some modding. Here's a 52 tooth Mod 1 on my E maxx with a Medusa Motor and a 18 tooth Mod 1 Motor gear.
Just don't mind the carnage. I had an accident. LOL Notice, there is alot of room in the adjustment to allow for a bigger motor pinion or a smaller one. It's pretty close to the middle with a 18 tooth. http://i160.photobucket.com/albums/t...m/DSC07252.jpg |
Right on...thanks for the help:yes:
I just ordered an MGT gear for about $3.50 so that is a cheap investment if I screw it up.:whistle: |
i had problem with BL motor bottoming out on trani and just went with larger(more teeth) pinion gear...up from 16t to 18t solved the problem!!
i have tons of slipper pads if you need a couple sets?
| All times are GMT -4. The time now is 12:34 AM. |
