-   -   mgm80/8s in a rusty? (https://www.rc-monster.com/forum/showthread.php?t=1826)
phildogg 12.18.2005 05:45 PM
what is everyones opinion on this set-up? or maybe a mgm80/basic 4200. thanx
phil
MetalMan 12.18.2005 09:46 PM
Should be powerful. It has the capability to run up to 12 cells (although not recommended). The newer MGM controllers are quite good.
RC-Monster Mike 12.18.2005 09:46 PM
Either will work quite well. I prefer the basic 4200 myslef, actually. It is smaller, has about the same feel power wise, but gets a better runtime and is small enough to be protected by the motor/tranny skid(Feigao will stick out past it by about 1/4").
SpEEdyBL 12.19.2005 05:09 PM
Just to clarify, you can't run the 8s on 12 cells.
MetalMan 12.19.2005 07:44 PM
Yes, I was speaking of the 4200 (which is rated for 65,000RPM, although this should not even be neared).
