Dogbone HELP
Need an approx 106mm 1/8th scale dog bone for the tracked CRT .5 - HELP!!!
I would contact Mike or RCAlloys. I've had bones from each and both are high quality. Make sure you tell them diameter of ball end as well...
Best I've found... http://www.advantagehobby.com/produc...8&cat=0&page=3
Also found these:
http://www3.towerhobbies.com/cgi-bin...?&I=LXPMN2&P=7 |
Again, I would verify that the ball at the end of the bones and the pins will fit the cups...
| All times are GMT -4. The time now is 05:31 PM. |
