Dimension Engineering Sport BEC
Is anybody using this BEC with their Sidewinder or MM ESC? Did you have to cut the red wire from the ESC? I just installed this BEC on my sidewinder without removing/cutting the red wire. Is this good or bad.
http://www.rc-monster.com/proddetail...portbec&cat=18 Thanks. |
That BEC has a throttle cable pass-through, which just allows the negative and signal wires through. So, it automatically disconnects the red wire without having to mod the throttle cable.
Thanks Brian.
For what it worth :wink: (right or wrong) I pulled my red wire on my MM.. But BrainG is the GOD of knowledge so I would go with what he said.:whistle:. Maybe hahhahaaa.. :rofl::rofl:
Have a great one Sir..:intello: |
God of knowledge... yeah, right. :smile:
I generally do the same (pull the red wire) in any BEC just to be consistent, but it's much easier to just use the pass-through feature. In the case of the SportBEC, you can actually follow the red wire PCB trace and you'll see it does not go anywehere on the BEC. |
| All times are GMT -4. The time now is 06:14 AM. |
