-   -   My conversion...with a plethora of problems :( (https://www.rc-monster.com/forum/showthread.php?t=18318)
edep345 01.27.2009 01:53 AM
I am using:
-Mamba Monster Max ESC
-Airtronics MX-3 FHSS
-Feigao 9XL
-Zippy 4s1p 5000mah lipo
[U]My problem:
The system is what I just got. When I received it, I tried to bind the transmitter to the receiver, all went well as I went through the normal procedures, the led stayed solid, the esc makes the proper double "beeps" and when I drive the car more than 8-10 ft. away from me, the fail-safe kicks in and I have no control over the car anymore.
Another issue I am having is that my motor does not have any movement after I program the ESC using the castle link. However, if I return all the settings to default, the car will work, but I have the same problem as I stated above...
*I really do not know if this is a receiver or ESC problem. I hope that anyone before that may have experienced or even heard of such problems can share their helpful insight with me...thank you for your time and consideration!
<a href="http://s162.photobucket.com/albums/t268/edep345/?action=view&current=China653.jpg" target="_blank"><img src="http://i162.photobucket.com/albums/t268/edep345/China653.jpg" border="0" alt="Photobucket"></a>
suicideneil 01.27.2009 02:11 PM
Make sure the castlelink firmware is the latest version- 1.20 from the castle website, that will eliminate one possible problem.
Sounds like a radio issue though with the failsafe kicking in- have a thorough prod and poke looking for loose connections or damaged wires/antenna. Beyond that, try another radio if possible.
magman 01.27.2009 06:20 PM
I agree w/Neil, a loose connection sounds like 1 prob.....try a different rx/ radio if you can.
