-   -   LifeP04? (https://www.rc-monster.com/forum/showthread.php?t=18355)
trev3813 01.28.2009 04:41 PM
LifeP04?
Umm, care to explain? Is it A123 cells? Decent?
http://www.hobbycity.com/hobbycity/s...8&ParentCat=85
lincpimp 01.28.2009 04:56 PM
Basically the same chemistry. Still heavy and require a 2p config to work adequately...
trev3813 01.28.2009 05:13 PM
Ah, was browsing on hobby city and saw that, Im runnin 6s lipoly, no A123
BrianG 01.28.2009 05:15 PM
A little off-topic, but does anyone know if their A123 dev kit contains all 4 cells or just one? Seems too cheap for the full dev pack, but a little expensive for one cell. The description says dev pack, which comes in a 4 pack IIRC...
What's_nitro? 01.28.2009 05:23 PM
It's a single cell. There's no way they could be selling (4) A123-branded cells that cheap. I think they mean it's the same cell you get in the dev. kit.
pedeboi364 01.28.2009 05:41 PM
ya, i was wondering the same as BrianG. A single cell is about $12-$15 at some places, and considering how much cheaper everything else on HC is... maybe someone can email them and get an explaination??
BrianG 01.28.2009 05:55 PM
Originally Posted by pedeboi364 (Post 256458)
...A single cell is about $12-$15 at some places, and considering how much cheaper everything else on HC is...
Yeah, that's where I was coming from...
suicideneil 01.28.2009 06:11 PM
*Thats what she said.*
What's_nitro? 01.28.2009 06:16 PM
*sigh*
suicideneil 01.28.2009 06:21 PM
What, you didnt expect me to pass that one up did you?
Anyway, I think the developer kit cells are more expensive as they are more like matched, hand-picked cells. Useless when you are buying them individually, but in a normal pack of 4 or whatever, it means they are more likely to stay in balance, like matched lipo cells in a pack for example...
bensf 01.28.2009 06:47 PM
LiFePO4 aren't the same as A123. The A123 uses the same LiFePO4 chemistry, but with a few additives. IIRC.
mohanjude 01.28.2009 08:31 PM
You are correct. A123 which is a propriety name for the process of 'doping' the anode and cathode with chemicals that enable the cell to discharge with a higher C rating. True A123 cells IMHO are much better than the cheap chinese imitations that are floating around. I have tried both and the A123 are much better suited for the purpose of Racing and Bashing.
highflier 01.28.2009 08:50 PM
those looked like true A123 cells. HC also sells knock of LiFe cells but they do not perform the same from what I have heard.
As for A123 cells they work just fine in my monster truck. They are a tad heavier but you can charge them so fast with just 2 packs you can run all day. Best way to get the cells are buy a dewalt 36 volt battery pack and havest the cells out of there. You should be able to get them for about 10.00
Highflier
pedeboi364 01.28.2009 08:57 PM
where can i get a dewalt pack cheap^^???
trev3813 01.28.2009 09:04 PM
$10? Where?!?!
