Mm & 13.5 ?
Im looking for a esc for my new tc4 & i have a ?. I will be using a speedpassion 13.5 motor . This is a sensored motor . How would this motor run on a MM with the sensor cable discounted ?.
I have ran a novak 4.5 and LRP 3.5 on my mamba max in a TC4. You will get some cogging during start-up (older firmware). I have not tried it with the new firmware since I'm now running castle 7700.
The newer 1.2 firmware is a big improvement in the starting algorithm. If going really slow, you might still see a little "chattering" (not really cogging), but only a problem if you ease into the throttle very slowly (like taking 10 seconds to go from neutral to WOT).
Will it hurt the motor running a sensored motor unsensored ?. |
Not at all. A sensored motor is simply a sensorless motor with a sensor attached to it. :smile:
Instead of taking the computer to the track, take the track to the computer. :smile:
Dunno. :neutral:
| All times are GMT -4. The time now is 03:33 PM. |
