Anyone notice the new clutch adaptors from Tekno!
Tell us what's going on Tekno. What's with the new 3 shoe and the new 2 shoe systems? I already use the current clutch system and love it.
2 shoe: http://www.impaktrc.com/product_info...oducts_id=3937 3 shoe: http://www.impaktrc.com/product_info...oducts_id=3891 |
The 2 shoe model is just an updated version of the original. The 3 shoe uses 1/8 scale clutch parts and bells.
I never had a good luck with the elektri-crap. I tried running it on my conversion but it was getting hot too quick.Mind you, I was using a 1/8 scale 4-shoe clutch shoe setup too.
http://i256.photobucket.com/albums/h...Picture010.jpg Here's my thread on how I installed a 1/8 scale clutch on my conversion. http://www.rc-monster.com/forum/showthread.php?t=16311 |
The 3-shoe is also a 1-piece design and provides the most tuning and clutch shoe options along with the best performance. The new 3-shoe with the .7mm springs is one of the best setups we've tried. As for the Elektri-Crap, I thought we emailed back and forth until your problem was solved. If not, give us some more details on your setup so we can try to help rather than calling our product a piece of crap. There are many reasons it can get hot, and the fact that we've run them competitively in truggies for over a year without issues leads me to believe there might be something in your setup that may be causing the problems (locked in 2nd gear by chance?). Or try the new 3-shoe... We are exchanging all of the old adapters for the new 2-shoe adapter free of charge (just pay $2 for shipping). Send us your old Elektri-Clutch to our address with a return address and return postage and we'll take care of the rest. Or, send us your old adapter and $10 and we'll upgrade you to our new 3-shoe adapter (clutch springs and shoes not included, but you may have some that work already off of your nitro). The new 3-shoe adapter (no shoes) will now be included in all of our conversion kits except the Losi's, which will include a full 2 shoe clutch. The reason for just including the adapter is that most people converting should have springs and shoes that will fit right on whereas the Losi 4-shoe clutch and clutch bells are not compatible with our new adapter. |
I just had a great day at Revelation today with no electrical issues and one minor mechanical issue. All while using Elektri-Clutch V1. I actually had so much run time that I ran out of battery in my 3PK and had to call it quits. |
Yeah, 'the locked in 2nd' is probably the cause of the excessive heat. Clutches need a certain RPM/gearing combo range to work properly and locking in 2nd takes the clutch out of that range. So if you want to keep the single speed, direct drive is probably the way to go.
We realize the clutch is not a perfect system, like lincpimp said, it's another option. Our new 3-shoe is pretty cool though and allows a greater range of the above mentioned RPM/gearing combos. With the thinner .7mm springs, it would probably work good on a single speed Revo. |
Keep on expecting a clutch-free conversion kit from Tekno. If that comes available I'll buy my second kit for my buggy.
James, I used to run the TeknoRC 1515 1Y on 5S on the revo. However, I had since taken the Neu out and installed the Medusa 36-70-2000 motor. I think there is enough motor in there and it just overpowers the clutch. Anyway, I'm happy with the pinions now so I'll run it that way until I get the itch to try the clutch again.
TeknoRC, how come you didn't go all the way with a 4-shoe? |
George16, there is no inherent benefit to a 4-shoe over a 3-shoe so we decided to go with the setup that is the most common and readily available. You can use our clutch shoes and springs or just about any others that are available (Kyosho, Mugen, Ofna, HB, AE, etc). We won't be doing a Losi compatible adapter since it is a much heavier setup and and we saw no extra benefit during testing. The trick with our new system is the thin springs. Since there is no motor to stall, we can run thin springs for great engagement. You can run thicker 1.0-1.1 springs as well if you want more of a nitro feel. The .7mm and .8mm springs feel very close to direct drive in our testing, just smoother. |
TeknoRC, I tried .8, .9 and 1.0 Mugen clutch springs. It wasn't doing any good. I even tried it withouth the springs. Can you send some of those thin springs you're talking about? Thanks.
I'm not aware of anyone else selling .8mm springs for 3-shoe systems, do you have a link or part #? Either way, I think we are comparing two different clutch systems.
what is the fix because i have battled this overheating clutch for a year on my revo, when i asked tekno they said it was fine even though it isnt, i am still replaceing clutch shoes every time i go to the track, if there is why didnt you guys email me about it?
| All times are GMT -4. The time now is 07:37 AM. |
