-   -   CCBEC vs. Novak HV UBEC (https://www.rc-monster.com/forum/showthread.php?t=18467)
SidewaysLS4 02.02.2009 11:41 AM
I'm setting up my speed buggy with a MM, which has that 5 volt internal BEC. Only thing is I want 6 volts to keep my servo speed up so my gyro setup works as well as possible. I got a CCBEC already, but I neglected to notice that I would need that CClink thing to actually set it to 6 volts. So more parts required...
I read though the forums and it seems that there was some sort of issues with the CCBEC's breaking and allowing full battery voltage to the rx when this happens, scary (man I wish I researched this more, lol). So I'm now thinking about the Novak HV UBEC, 6 volts, and roughly the same price as a CClink to get the needed 6 volts. Seems to have a nice big cap on it to kill noise as well. Funny thing, Tower emailed me a $20 off $50 coupon, just in time for this :party:
What's the word on these BEC's? Good, Bad?
emaxxnitro 02.02.2009 12:23 PM
The ccbec is fine. If you mount it right I doubt you will have any problems. I have 2 on my rig 1 for servos and one for fans and led's one at 6v and 1 at 9 volts
himalaya 02.03.2009 06:16 AM
$20 off $50 coupon ?? That's a crazy discount. as a member the best coupon I've got is $75 off $300. How can you get it?
SidewaysLS4 02.03.2009 02:08 PM
I switched email address on my account from home to work a couple weeks ago, then this 20 off 50 showed up in my home email. Described as an introductory coupon of some sort, gotta get more of 'em!
SpEEdyBL 02.03.2009 06:32 PM
:surprised: Ima go do that too. :yipi:
bensf 02.03.2009 06:39 PM
When a switching BEC fails it will let the full voltage through. Its the same for the CCBEC or the Novak BEC or any other switching bec.
himalaya 02.04.2009 02:31 AM
There are many ways to fail. if the MOSFET get shorted, the situation you described will happen, but if the MOSFET get broken(none conductive), the BEC will output 0V.
jhautz 02.04.2009 10:07 PM
What version on MMM do you have? The V1 I have is 5v bec ouput but the V2 and V3 both show 6v output when I test it with a meter. If you have a newer MMM its putting out 6v even though the specs say 5v. You probably dont even need the external BEC if you are only looking for 6v.
SidewaysLS4 02.05.2009 10:04 AM
It is a MM, not MMM. 1:10 stuff.
azjc 02.05.2009 10:24 AM
if you are concerned about a BEC failing the only way is to use a RX pack. The Heli guys use a 2s lipo pack with a voltage regulator
jhautz 02.05.2009 11:05 AM
Gotcha. Didnt read close enough.
BrianG 02.05.2009 11:12 AM
If using a seperate rx pack is not desired, you can do a hybrid system. Use any switching BEC to bring down the battery voltage to 7-7.5v, and then use a linear regulator to take care of that extra 1-1.5v. Wouldn't be the best efficiency-wise, but better than using a linear regulator solely, or dealing with a possible BEC failure...
himalaya 02.09.2009 07:07 AM
Good idea, that also results in lowest possible switching noise, very clean BEC output.
