-   -   Solar charger (https://www.rc-monster.com/forum/showthread.php?t=18724)
PedeBasher 02.12.2009 05:37 PM
Solar charger
Does anyone have any experience with solar panels?
While sitting in math today (horribly boring), I was looking at my calculator. I saw the solar panel it has on it and it only has 6 screws in the back. That got me thinking. It cant be too hard to extract the panel now could it?
Well anyway, I want to start small. Maybe with my Micro-T charger and 6 or so panels rigged into it. If that works I will go bigger into something maybe for my 606i.
Does anyone think this is possible? I know if I dont have a lot of panels I probably wont get a lot of amps but I wont worry about that now. I just want to know if it is do-able.
Some may think its stupid but for those of us that dont have cars to use to plug our chargers into, its brilliant. Cheap, easy, and ultimately light weight.
I could be a new revolution of R/C gear...:yes:
pedeboi364 02.12.2009 05:52 PM
damn wouldn't that be great. No more buying heavy, annoying, expensive power supplies!!! Call me ur official helper-tester-outer!!
PedeBasher 02.12.2009 05:59 PM
Thats exactly what I am thinking. If I get one working I think it would be a huge innovation.
Im sure I can get old solar panels by asking neighbors/looking around Craigslist for used calcs and solar malibu lights.
If anyone has some good info on solar panels, please post it or PM me about it.
kostaktinos_mt 02.12.2009 06:01 PM
not a cheap solution...
example:
http://www.allelectronics.com/make-a...R-PANEL/1.html
you will need a minimum of two of these [~2.3amps /17v total -in full direct sunlight] for a small charger, able to charge a 2s lipo at around 4amps...
thus, the cost will be around 400$ [not including any regulating array that might be involved]...
PedeBasher 02.12.2009 06:06 PM
Hmm... Think if I rounded up like 100 malibu panels (bought 2" by 2" if you dont know what im talking about) it could be done?
But for now, like I said, I just want to get my feet wet with a Micro-T charger.
Dagger Thrasher 02.12.2009 06:14 PM
While it's a nice idea, it's not going to happen for a charger of any real size; solar cells just aren't anywhere near efficient enough yet, so you'd need a MASSIVE array set up to power a normal charger from. For that kind of output, you'd probably be better off setting up a Pb battery solar charging system which charges throughout the day and then powers the charger from the battery; much more reliable. Even then, you'd still need a massive array.
As for your Micro-T charger though...that *might* be do-able. If I remember rightly, the Losi LiPo charger's max output is 150mA, though it has a standard AC 120V input, being a wall charger. You'd need to disassemble it and remove the transformer, which I'd imagine steps-down to around 12V. You could then just hitch up a suitable solar voltage regulator to keep the input steady under varying sunlight, and then setup an appropriate cell array which are capable of outputting at least 250mA total, at a guess (you want to be able to charge when it's cloudy!). You'd want cells of a higher maximum voltage than 12V as that'd allow headroom for when the sunlight fades; around 18V I guess would be ideal. You can mess around with the wiring config, so series-up cells of lower voltages, etc. Or use one, large 12V panel; they usually stay at a fairly constant 12V with variable current output. The voltage reg would probably have a built-in cutoff for when voltage dips too far below 12V.
That's all just a very rough plan and you'd have to look into what actual cells you can find, but it is viable...if a bit of a hassle lol.
bruce750i 02.12.2009 06:18 PM
Here are few that are a little bigger than whats on your Texas Instrument. http://search.harborfreight.com/cpis...rd=solar+panel
PedeBasher 02.12.2009 06:25 PM
Hmm... It was a thought. I wanted your guys opinion. I think I will still pursue the Micro-T idea. If I have to, I will step down even further to a MCX charger and try that, just to say I did it. :lol:
