-   -   If I were jumpers, where would I hide? (https://www.rc-monster.com/forum/showthread.php?t=1874)
R00ST 12.24.2005 08:42 PM
I feel like such a noob posting so many new threads (really sorry about this..) I did search and I know I have seen pics on here in the past of 9920 where people show where the jumpers are. I dont want to risk burning up the internal BEC running on 14 cells (mike suggested running the receiver pack until I get my ubec, so that is what I will do).
If someone has a picture or knows where one is at, that shows the area of the red/black jumpers, that would be very helpful! I cant see either by looking into the battery lead area, and hate to just start hacking away all the heatshrink.
Thanks again guys :)
Gustav 12.24.2005 10:40 PM
No pic i'm afraid but the red jumper is at the power(battery) wires end of the controller on the underside under the +ve(red) power wires.You should be able to see the end of it if you look under the red wires.The black jumper is behind the red jumper and in a bit.(you can see the outline of it where the heat shrink is shrunk over it).Hope this helps.
JOHNNYMAXXIMA 12.24.2005 10:43 PM
And yes, you are going to have to hack away at your heat shrink.:D
Just go back where you cut it and and wrap it once or twice around with electrical tape.
RCcarnut 12.26.2005 08:11 AM
The red jumper you should see without removing the shrink wrap. Although my 9918 came without a red jumper and I had to find one. I just used a computer jumper.
Papa 12.26.2005 08:15 AM
Check out this wiring thread on the first page their is aphoto of my esc showing the UBEC.
nbcaznmaster 12.26.2005 09:06 AM
Re: If I were jumpers, where would I hide?
dont worry bout ti! i got about 1000 posts and i still am a newb! yes...you have to hacke the heatshrink. Dont tyr to get it out with pliers or anythign i chipped mine trying to avoid hacking.
