Putting UE knuckle heads on FLM hybrid bulks
If you put UE Knucklehead shock towers on FLM hybrid bulks did you dremel the tower or the bulk? I really hate to dremel the towers but the tower hits right on the top hex. Anybody replace this hex with a screw? Do you think that would work?
a screw would work. I ground my towers, but they weren't ue towers. I'd switch to a screw and grind as little as possible, but a little grinding is unevitable.
Mark, can you post a pic?
http://pic20.picturetrail.com/VOL143.../354835910.jpg
The top hex head screw holds the tower up so that the holes don't line up. I am thinking a button head screw would work. |
| All times are GMT -4. The time now is 04:13 AM. |
