-   -   3 MMM's all toast......WTF?? (https://www.rc-monster.com/forum/showthread.php?t=18856)
jzemaxx 02.18.2009 02:29 AM
I'm usually pretty quiet about this stuff, but I have gone through 3 MMM's so far in just a few short months. All of them keep doing the same thing. I run them for about 2-3 weeks no problem on practice runs at the track, then they shut off and never turn on again. WTF?? This is ridiculous!! Is their some new version of the MMM that has addressed this problem. I have a race on Sat. (this weekend) and now have no ESC to run :grrrrrr:
BTW: the setup is a MMM on 4S, 1521 1.5D and geared for only 35mph. Motor and ESC don't even begin to get warm.
BrianG 02.18.2009 02:43 AM
Hmm, when I hear something like this, I tend to look deeper. Could it be a servo is shorting out (or under very heavy load) toasting the BEC? Things like that. Sometimes, seemingly unrelated items can cause headaches.
Also, make sure the ESC has version 1.20 firmware.
jzemaxx 02.18.2009 03:02 AM
All of them have had the 1.20 FE, also the BEC is out of the loop. Using a UBEC. Also the steering servo has been swapped since the 2nd MMM was toast went from a Hi-tec to a JR8711, so its not the servo. Also my buddies MMM did the same thing on his E-revo after 3 weeks or so as well. Very upset at this point since the 2nd race of the season I will be scambling to borrow a ESC from someone.
big greg 02.18.2009 08:00 AM
i myself run only mm's just for this, reason, im not quite sold on these yet
tom255 02.18.2009 08:14 AM
Just to be sure... If you use UBEC did you removed from connector red wire on ESC Signal cable?
What TX/RX system you have?
johnrobholmes 02.18.2009 09:56 AM
What version of MMM were they?
jzemaxx 02.18.2009 11:47 AM
Yes red cable removed and DX2.0 is the TX/RX. I can put my cheap Turnigy 100A controller and stick 8S on it and run it all day and never have a problem. I have had that controller for almost 2 years now.....no problems with it, or my HV110.
jzemaxx 02.18.2009 11:48 AM
1 was V2 and the latest 2 have been V3
azjc 02.18.2009 12:01 PM
contrary to what Castle says, IMO the HV 110 makes a very good truck ESC, I am not sold on the MMM.
jayjay283 02.18.2009 12:19 PM
My V1 stopped working yesterday like that. Just decided it wasn't pushing my Gmaxx around anymore and shut off. It works with the castle link but nothing when plugged in, dead bec ? Poor guy almost lived a year. V2 and V3's running fine
BrianG 02.18.2009 12:36 PM
yeah, sounds like a dead BEC. The Castle Link powers the brains when connected, so it makes sense that it works when plugged in.
himalaya 02.18.2009 01:29 PM
pay attention to your fan. I just experienced a overheat shut down, after getting the truggy back to the pit I found the fan was dead. Offroad dirt are too cruel to the ESC.
bdebde 02.18.2009 02:09 PM
Did you check the switch?
jzemaxx 02.18.2009 02:30 PM
Yes...tried bypassing it.....still nothing. It won't even connect with Castlelink
slimthelineman 02.18.2009 09:19 PM
yeah thats a bummer, a few people on this forum have had a MMM fail myself included. why do we keep running it? cause its fricken awsome when it works! also where is your esc in the car? is it on the chassis or some where else? i run an rc8 and have found my MMM's like it more low in the car on the chassis. the guys at the local track all run the novak stuff. partly due to the small indoor track and influence by the factory guys. since i have been racing there over the past month ALOT more MMM combos are showing up. dont give up jzemaxx, castle cares about its customers.
