My E-jato
Well I decided to convert my jato over to Electric.. I think it turned out good, I have been running it like this for a while on 2s/3s.. It is locked into 2nd running MM with a Medusa 36-50-4800kv Its a pretty sweet setup..
http://i510.photobucket.com/albums/s...VERSION006.jpg http://i510.photobucket.com/albums/s...xX/jato006.jpg http://i510.photobucket.com/albums/s...xX/jato007.jpg http://i510.photobucket.com/albums/s...xX/jato004.jpg http://i510.photobucket.com/albums/s.../e-jato005.jpg http://i510.photobucket.com/albums/s...sxX/Rcs018.jpg Heres a picture with the stock slash tires.. They work rather good on the Jato compared to the Slash.. http://i510.photobucket.com/albums/s...slash008-1.jpg Also heres a video of the slash/E-jato.. Its mostly E-jato.. just get through the first 2 minutes or so.. :wink: http://www.youtube.com/watch?v=1SlizOxfTDE |
Nice! How do you like the power of the medusa on 3s? How does it compare to the mamba on 3s?
Doesn't even compare...:na::na:
lol I'm ordering a 4800kv 50mm medusa in just a few weeks....I already have my 30c lipos. :na::na:
On the Slash, I tried a 5700 setup on 10 NiMH cells. That too did not come even close to comparing to a Medusa 36-50-2200 on 4s. |
Should be fun.. Hope you get it soon
Hey 450, How do you like that 2s hard case flightmax pack? I am thinking about getting one...
I had 2 of them for my e-savage to run in a series.. but then one of them died.. I wouldn't get them.. There no warranty packs pretty much...
Well I am trying to get to 100mph with my jato.. That is my goal.. I have the gearing and all to make it.. I just need to get that all to the ground.. On paper it should be more than enough.. I need to find a good body for this thing.. any reccomendations?
http://i510.photobucket.com/albums/s.../e-jato009.jpg \http://i510.photobucket.com/albums/s...-jato007-1.jpg http://i510.photobucket.com/albums/s...-jato008-1.jpg http://i510.photobucket.com/albums/s...-jato006-1.jpg http://i510.photobucket.com/albums/s...edE-jato2s.jpg http://i510.photobucket.com/albums/s...edE-jato3s.jpg http://i510.photobucket.com/albums/s...edE-jato4s.jpg |
Nice setup. What did you do to get the slash rims to work on the fronts. They are a nice tire for a setup that's closer to the ground. I run them on my LS10 and they work great. Got a set from the slayer that I was going to run on the Jato also with some 14mm hub adapters for the rear but still need to figure out the fronts. Don't really want to convert to a rustler/stampede front end due to the already $$ spent on Jato rims and 17mm adapters that would then be useless.
the tire/wheel combo will be your problem for your goal of 100mph....I would try to use more of a street tire
http://i510.photobucket.com/albums/s...hubjato001.jpg |
Well I decided to do a bit of an update on the Jato and decided not to go for the 100mph.. I had everything fine but the MM ran soo hot it melted the Positive lead off of the board...So I decided to just turn it into a all out fun basher.. Going to get 1/8 buggy tires and a 4s lipo for it and my slash...Along with my 3s..Also took the wing and the wheelie bar off of my E-savage (since im not running it anymore ESC & Motor in slash ) and put it ion the jato.. I also plan on getting some longer shocks for the E-jato... Might use the slash shocks.. Should be good.
http://i510.photobucket.com/albums/s...ooooooo002.jpg http://i510.photobucket.com/albums/s...ooooooo004.jpg http://i510.photobucket.com/albums/s...ooooooo003.jpg |
| All times are GMT -4. The time now is 02:20 AM. |
