Braking?
How do you tune the brakes on the esc? on the reg revo, its really easy. This is for racing purposes. The braking is too stiff for teh track. I try to brake and the car flips over when i turn. Is there a way to adjust this?
Yeah there is. Adjust your end point adjustment on the controller. If this is not and optioin you can program it in with a program cable if you run a bk controller. A thrid option is not to push the controler as far in to reverse.
| All times are GMT -4. The time now is 07:01 AM. |
