Torque twist
I noticed i have a little torque twist on my crawler . Under power the LR wheel compress & the RF lifts . So i put thicker oil 60w in the LR & added more preload . It still has a little . There is no added weight in the FR wheels yet . It has duratrax 3 1/5 inch aluminum shocks . this is how my truck is set up now . Did i put the thicker oil in the right shock ?.
http://skellyo.com/fs/DMGCrawler/DMGCrawler3.JPG |
I believe that converting the upper 3 link to 4 link will help as well. The Crawler Store among others sells the conversion pieces.
Read the text in this item description...it tells you how to mount the rear links like I was telling you about.
http://www.tcscrawlers.com/On-Sale-4...g-p-16612.html |
I all ready read that . I wanted to try the shock first . Mounting the links like that wont hurt the crawling ability of the truck ?. |
I just made my own 4 link using a piece of 5mm lexan for my son's AX 10. Works well, and didn't affect the crawling ability of the truck at all.
Shafties will always have some torque twist...
If you have not added weight to the front wheels yet it will make a huge difference in crawling ability. It will not help torque twist though. Usually some added preload on the right (not sure of the side, but it would be the side that compresses while going forwards) rear spring will help with torque twist. Some link setups do twist more than others though, my j-keeper does not really twist, even with the big outrunner... |
i have 4 links front and rear
70wt oil on LR and a bit of preload. im getting a good 61 degrees with it. There will always be Twist tho. Just gotta learn to drive with it:neutral: |
ANdrew32, what shocks are you suing on your setup?
Running Badland tires. Ill see if i cant get some footage today at the LHS |
How much preload to use on your crawler shocks ?.
I use enough preload to keep the springs loaded when fully drooped. I also add internal springs to make the rig 50/50 droop/sprung. With the way that crawler is set up, you could stand up the rear shocks more too.
To try and combat the torque twist, you could bring your lower links in closer to center at the chassis side. You need to bring the roll center down a bit. Your shocks are too short to have a 50/50 setup though, it is set up best for full compression. |
Thank you john. I stood the shocks as far i could. They are now at about the 12:05 postion . If your looking at the old pic . That is 2 holes back . http://skellyo.com/fs/DMGCrawler/DMGCrawler3.JPG What do you think about using hi clearence links on the FR ?.My crawler has the tcs 4 link convestion plates on the FR & RR the rear. Im running the asemetrical setup to help with the torque twist on the RR . How should i mount the FR upper links to the TCS plate, on the top or bottom or does it not matter ?. |
| All times are GMT -4. The time now is 05:13 PM. |
