Dead mamba max esc ?
I was overheated my motor and my mamba max esc today both over 200f + and now when I try it it seem to cogging alot when I push on the gas throttle and when I run it for maybe only 5 sec the esc get hot very very fast for nothing ... but not the motor or the batteries ...
If the motor got that hot, then the magnets inside it probably lost their strength. When this happens, the motor basically becomes a short circuit. The MM got hot because it was sending power into this short circuit. I don't know if CC will cover damage due to over-heating. Try running another similar motor in the vehicle (if you have another motor...) and see if the MM still operates correctly. If it does, then I would just bite the bullet and pick up a new motor.
You probably demagged your motor. What's your setup?
it is my 1/8 kyosho st-r truggy.
specs : mamba max esc bec disabled I was using 4 AA rechargeable for now.. kd36 7xl motor ( 2380kv ). 4s lipo 15c 6400mah. 50t spur. 13t pinion. |
It seems like a stable setup. Not over geared, and no off-the-wall motor RPM. Though, I am not the "truggy master" on this forum. Do you race with this truck? How's the drive train as far as binding? The motor was somehow overloaded and that made everything heat up. Any rocks in the spur? :whistle:
no I dont really know why is heating up I buyed it from someone who have used it only 2 times.. runned it on 12 cells and still heating alot but not like today when I was received my 4s lipo it have going over 200f +
and no I dont racing only playing into my yard.
If it was heating up with the NiMH and then turn to worse with the lipos, I guess the motor was already shot before you even used it.
maybe :sarcastic:
for now someone want to sell me this motor for cheap : http://holmeshobbies.com/product.php...3&cat=3&page=1 do you think it can do the job for awhile ? |
You also stated that you use it in your yard. Might be hard to beleive but grass put a huge amount of stress on the electronics. Also the RPM's are a touch on the high side for a truggy, IMO you should have about 2000kv on 4s. My suggestion is to def bite the bullet on the motor. Spend a little more and buy a Medusa or the CC/neu from Mike $140 or less depending on what you choose. The MM should still be fine but don't keep trying to use it with that motor!
it is snowy there not grass :mdr:
since my KB36-7XL was dead ( overheating ) here is my new setup :
Motor : Neu 1515/1.5D/F 2700kv ( 5mm Shaft ) Speed : Mamba Max 1/0 ESC ( Bec Disabled ) Battery : TrueRC 14.8V 6400mAh 15C 4S2P ( 96A Cont. 128A Burst. ) Gearing : 50t Spur - 13 Pinion. how do the runtime would be on this ? and all would run perfect and cooler no overheating problems ? http://img119.imageshack.us/img119/2500/setup.jpg |
Personally I think that is too much of a motor for a poor MM and a 96amp continuous battery... I would look at a 1Y (maybe castle variety) from Mike
| All times are GMT -4. The time now is 12:08 AM. |
