-   -   Opening Medusa (https://www.rc-monster.com/forum/showthread.php?t=19066)
Jabe 02.28.2009 09:06 AM
Opening Medusa
So id like to open up my medusa, to clean it from inside, is that rear endplate glued?
How it should be opened, that i wouldnt damage windings?
Its Afterburner V2 80mm, if that makes any difference.
transtalon 02.28.2009 09:56 AM
Medusa
I wouldn' open it. I would simply blow it with some high pressure compressed air. This is much safer and easier.
RUSTED 02.28.2009 02:35 PM
yes , i think its glued . coz the rear endplate on mine used to pop out everytime i drive my car till i got the rcm motor clamp, so i woudnt open it u m8 damage somethn i suggest doing wat transtalonn said
Jabe 02.28.2009 04:06 PM
Well how about, when you need to change those bearings?
Im using RCM heatsink with clamp, so it wont get loose when driving.
lincpimp 02.28.2009 11:27 PM
Tap the shaft on a solid object, like a solid block of wood. Make sure the motor is perpendiculat to the solid object. I slightly bent the rear plate when popping it off, so be careful.
